20 years agobuildroot to build toolchain on Linux
TO_BE_DONE
20 years agohi hippo
I have problem at config the kernel.... [jay@localhost linux-2.6.16.1]$ make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- menuconfig no emulation specific options. HOSTCC scripts/kconfig/lxdialog/checklist.o In file included from scripts/kconfig/lxdialog/checklist.c:24: scripts/kconfig/lxdialog/dialog.h:31:20: curses.h: 沒有此一檔案或目錄 In file included from scripts/kconfig/lxdialog/checklist.c:24: scripts/kconfig/lxdialog/dialog.h:128: syntax error before "use_colors" scripts/kconfig/lxdialog/dialog.h:128: warning: type defaults to `int' in declaration of `use_colors' scripts/kconfig/lxdialog/dialog.h:128: warning: data definition has no type or storage class scripts/kconfig/lxdialog/dialog.h:129: syntax error before "use_shadow" scripts/kconfig/lxdialog/dialog.h:129: warning: type defaults to `int' in declaration of `use_shadow' scripts/kconfig/lxdialog/dialog.h:129: warning: data definition has no type or storage class scripts/kconfig/lxdialog/dialog.h:131: syntax error before "attributes" scripts/kconfig/lxdialog/dialog.h:131: warning: type defaults to `int' in declaration of `attributes' scripts/kconfig/lxdialog/dialog.h:131: warning: data definition has no type or storage class scripts/kconfig/lxdialog/dialog.h:143: syntax error before '*' token scripts/kconfig/lxdialog/dialog.h:143: warning: function declaration isn't a prototype scripts/kconfig/lxdialog/dialog.h:146: syntax error before '*' token scripts/kconfig/lxdialog/dialog.h:146: warning: function declaration isn't a prototype scripts/kconfig/lxdialog/dialog.h:147: syntax error before '*' token scripts/kconfig/lxdialog/dialog.h:147: warning: function declaration isn't a prototype scripts/kconfig/lxdialog/dialog.h:148: syntax error before '*' token scripts/kconfig/lxdialog/dialog.h:148: warning: function declaration isn't a prototype scripts/kconfig/lxdialog/dialog.h:149: syntax error before '*' token scripts/kconfig/lxdialog/dialog.h:150: warning: function declaration isn't a prototype scripts/kconfig/lxdialog/dialog.h:151: syntax error before '*' token scripts/kconfig/lxdialog/dialog.h:151: warning: function declaration isn't a prototype scripts/kconfig/lxdialog/checklist.c:31: syntax error before '*' token scripts/kconfig/lxdialog/checklist.c:33: warning: function declaration isn't a prototype scripts/kconfig/lxdialog/checklist.c: In function `print_item': scripts/kconfig/lxdialog/checklist.c:37: warning: implicit declaration of function `wattrset' scripts/kconfig/lxdialog/checklist.c:37: `win' undeclared (first use in this function) scripts/kconfig/lxdialog/checklist.c:37: (Each undeclared identifier is reported only once scripts/kconfig/lxdialog/checklist.c:37: for each function it appears in.) scripts/kconfig/lxdialog/checklist.c:38: warning: implicit declaration of function `wmove' scripts/kconfig/lxdialog/checklist.c:38: `choice' undeclared (first use in this function) scripts/kconfig/lxdialog/checklist.c:40: warning: implicit declaration of function `waddch' scripts/kconfig/lxdialog/checklist.c:43: `selected' undeclared (first use in this function) scripts/kconfig/lxdialog/checklist.c:44: warning: implicit declaration of function `wprintw' scripts/kconfig/lxdialog/checklist.c:44: `status' undeclared (first use in this function) scripts/kconfig/lxdialog/checklist.c:47: warning: implicit declaration of function `mvwaddch' scripts/kconfig/lxdialog/checklist.c:47: `item' undeclared (first use in this function) scripts/kconfig/lxdialog/checklist.c:49: warning: implicit declaration of function `waddstr' scripts/kconfig/lxdialog/checklist.c:52: warning: implicit declaration of function `wrefresh' scripts/kconfig/lxdialog/checklist.c: At top level: scripts/kconfig/lxdialog/checklist.c:59: syntax error before '*' token scripts/kconfig/lxdialog/checklist.c:61: warning: function declaration isn't a prototype scripts/kconfig/lxdialog/checklist.c: In function `print_arrows': scripts/kconfig/lxdialog/checklist.c:62: `win' undeclared (first use in this function) scripts/kconfig/lxdialog/checklist.c:62: `y' undeclared (first use in this function) scripts/kconfig/lxdialog/checklist.c:62: `x' undeclared (first use in this function) scripts/kconfig/lxdialog/checklist.c:64: `scroll' undeclared (first use in this function) scripts/kconfig/lxdialog/checklist.c:76: `height' undeclared (first use in this function) scripts/kconfig/lxdialog/checklist.c:79: `item_no' undeclared (first use in this function) scripts/kconfig/lxdialog/checklist.c:79: `choice' undeclared (first use in this function) scripts/kconfig/lxdialog/checklist.c: At top level: scripts/kconfig/lxdialog/checklist.c:95: syntax error before '*' token scripts/kconfig/lxdialog/checklist.c:96: warning: function declaration isn't a prototype scripts/kconfig/lxdialog/checklist.c: In function `print_buttons': scripts/kconfig/lxdialog/checklist.c:97: `width' undeclared (first use in this function) scripts/kconfig/lxdialog/checklist.c:98: `height' undeclared (first use in this function) scripts/kconfig/lxdialog/checklist.c:100: `dialog' undeclared (first use in this function) scripts/kconfig/lxdialog/checklist.c:100: `selected' undeclared (first use in this function) scripts/kconfig/lxdialog/checklist.c: In function `dialog_checklist': scripts/kconfig/lxdialog/checklist.c:117: `WINDOW' undeclared (first use in this function) scripts/kconfig/lxdialog/checklist.c:117: `dialog' undeclared (first use in this function) scripts/kconfig/lxdialog/checklist.c:117: `list' undeclared (first use in this function) scripts/kconfig/lxdialog/checklist.c:117: warning: left-hand operand of comma expression has no effect scripts/kconfig/lxdialog/checklist.c:121: warning: implicit declaration of function `endwin' scripts/kconfig/lxdialog/checklist.c:122: warning: implicit declaration of function `fprintf' scripts/kconfig/lxdialog/checklist.c:122: `stderr' undeclared (first use in this function) scripts/kconfig/lxdialog/checklist.c:140: `COLS' undeclared (first use in this function) scripts/kconfig/lxdialog/checklist.c:141: `LINES' undeclared (first use in this function) scripts/kconfig/lxdialog/checklist.c:143: `stdscr' undeclared (first use in this function) scripts/kconfig/lxdialog/checklist.c:145: warning: implicit declaration of function `newwin' scripts/kconfig/lxdialog/checklist.c:146: warning: implicit declaration of function `keypad' scripts/kconfig/lxdialog/checklist.c:146: `TRUE' undeclared (first use in this function) scripts/kconfig/lxdialog/checklist.c:166: warning: implicit declaration of function `subwin' scripts/kconfig/lxdialog/checklist.c:199: warning: implicit declaration of function `wnoutrefresh' scripts/kconfig/lxdialog/checklist.c:201: warning: implicit declaration of function `doupdate' scripts/kconfig/lxdialog/checklist.c:204: warning: implicit declaration of function `wgetch' scripts/kconfig/lxdialog/checklist.c:211: `KEY_UP' undeclared (first use in this function) scripts/kconfig/lxdialog/checklist.c:211: `KEY_DOWN' undeclared (first use in this function) scripts/kconfig/lxdialog/checklist.c:221: `FALSE' undeclared (first use in this function) scripts/kconfig/lxdialog/checklist.c:222: warning: implicit declaration of function `scrollok' scripts/kconfig/lxdialog/checklist.c:223: warning: implicit declaration of function `wscrl' scripts/kconfig/lxdialog/checklist.c:284: warning: implicit declaration of function `delwin' scripts/kconfig/lxdialog/checklist.c:288: `KEY_LEFT' undeclared (first use in this function) scripts/kconfig/lxdialog/checklist.c:289: `KEY_RIGHT' undeclared (first use in this function) /usr/include/bits/string2.h: At top level: scripts/kconfig/lxdialog/dialog.h:131: warning: array `attributes' assumed to have one element make[2]: *** [scripts/kconfig/lxdialog/checklist.o] Error 1 make[1]: *** [menuconfig] Error 2 make: *** [menuconfig] Error 2 http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif thx http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/laugh.gif
