20 years agobuildroot to build toolchain on Linux
TO_BE_DONE
20 years ago --- Quote Start --- originally posted by phill@Apr 11 2006, 12:15 PM hi hippo
i can run the boa webserver on my board,but i can use cgi.
<div class='quotetop'>quote
--- quote end ---
--- quote start ---
binfmt_flat: loading file :/home/httpd/hello.cgi --- Quote End --- how to make hello.cgi to flt format? <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14223)</div> [/b] --- Quote End --- this thread is getting too long, please post your question/discussion over the uClinux forum. It will be easier to follow. I am not good at network. Maybe other expert can help out. please check ~/uClinux-dist-test/user/cgi_generic . if there is no perl, you will need to compile a c with elf2flt option.
