20 years agobuildroot to build toolchain on Linux
TO_BE_DONE
20 years agohi nippo
I can find nios2-linux-uclibc-gcc in ~/buildroot/build_nios2/staging_dir/bin dir and check the "PATH=$PATH:/buildroot/build_nios2/staging_dir/bin" follow. [jay@localhost ~]$ cd ~/buildroot/build_nios2/staging_dir/bin [jay@localhost bin]$ ls nios2-linux-addr2line nios2-linux-uclibc-as nios2-linux-ar nios2-linux-uclibc-c++ nios2-linux-as nios2-linux-uclibc-cc nios2-linux-c++ nios2-linux-uclibc-c++filt nios2-linux-cc nios2-linux-uclibc-cpp nios2-linux-c++filt nios2-linux-uclibc-elf2flt nios2-linux-cpp nios2-linux-uclibc-flthdr nios2-linux-g++ nios2-linux-uclibc-g++ nios2-linux-gcc nios2-linux-uclibc-gcc nios2-linux-gcc-3.4.6 nios2-linux-uclibc-gcc-3.4.6 nios2-linux-gccbug nios2-linux-uclibc-gccbug nios2-linux-gcov nios2-linux-uclibc-gcov nios2-linux-gprof nios2-linux-uclibc-gprof nios2-linux-ld nios2-linux-uclibc-ld nios2-linux-nm nios2-linux-uclibc-ld.real nios2-linux-objcopy nios2-linux-uclibc-nm nios2-linux-objdump nios2-linux-uclibc-objcopy nios2-linux-ranlib nios2-linux-uclibc-objdump nios2-linux-readelf nios2-linux-uclibc-ranlib nios2-linux-size nios2-linux-uclibc-readelf nios2-linux-strings nios2-linux-uclibc-size nios2-linux-strip nios2-linux-uclibc-strings nios2-linux-uclibc-addr2line nios2-linux-uclibc-strip nios2-linux-uclibc-ar [jay@localhost bin]$ PATH=$PATH:/buildroot/build_nios2/staging_dir/bin [jay@localhost bin]$ nios2-linux-uclibc-gcc -v bash: nios2-linux-uclibc-gcc: command not found Occur the same question again. Why can't find nios2-linux-uclibc-gcc command. Where i setting error? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif Thank in advance !
