20 years agobuildroot to build toolchain on Linux
TO_BE_DONE
20 years ago --- Quote Start --- originally posted by jay_1025@Apr 10 2006, 08:46 PM hi hippo
i have a problem ........
[jay@localhost linux-2.6.16.1]$ make arch=nios2nommu cross_compile=nios2-linux-uclibc- hwselect sysptf=std_1c20.ptf
/bin/sh: nios2-linux-uclibc-gcc: command not found
make: nios2-linux-uclibc-gcc: command not found
running hwselect
error: could not open system ptf file.
q:
1. i do'nt know "std_1c20.ptf" at which dir on linux platform.
2. i use de2 dev board.
if i want to use up4_sd_card_audio example and how to use "hwselect sys" on linux platform?
ps : i don't install quartus ii on my linux platform.
thx
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14191)
--- quote end ---
--- Quote End --- if you use DE2, the ptf and sof are on the DE2 support CD, DE2_System/DE2_demonstrations/DE2_SD_Card_Audio/nios2_0.ptf and DE2_SD_Card_Audio.sof you don't need QuartusII on Linux. check your nios2-linux-uclibc-gcc in ~/buildroot/build_nios2/staging_dir/bin , if you have them, then check your PATH variable, follow step4 in the guide. PS, this thread is getting too long, please post your questions on the uclinux forum.
