20 years agobuildroot to build toolchain on Linux
TO_BE_DONE
20 years agoI have alreay install nios2 toolchain use build0320.and it work fine.
I finded a small question. The mxapp.diff patch failed, because the diff not cp to ~/apps.but you can handwork the step later. the other question: I port a ncurses program to nios2 uclinux. I writed the Makefile follow ~/apps/ftpd/Makefile. Compile it successed. But the nios2 uclinux will restart when I exec it.
