20 years agobuildroot to build toolchain on Linux
TO_BE_DONE
20 years ago --- Quote Start --- originally posted by hippo@Feb 17 2006, 12:40 AM hi alex,
1. the ccache is not required, you can disable it.
cd ~/buildroot
make menuconfig
toolchain options--> [ ] enable ccache support?
make
2. ignore the watchdog patch fail of the new kernel. you can update the watchdog makefile later.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12762)
--- quote end ---
--- Quote End --- Hi hippo: 1)I am install nios2 toolchains on PC of my home.In process, I meet the question of not to concect the ccache download web again. follow you above guide , I disable the option of ccache support, then make it again. But make failed. 2)suggest: can you change the ccache download web site in the builld fille,or download all *.tar.bz2, *.tar.gz to download dir from interrelated web site before exec the step "./build0207".Because In sometimes some case of build fail by some websites not steady. the other way can you give the method of how to instead the original connect web site in your build file? Thank you.
