20 years agobuildroot to build toolchain on Linux
TO_BE_DONE
20 years agohi hippo:
I make boa ,dhcp, netsnmp ,but failed. The failed information: [alex@localhost uClinux-dist-test]$ make subdirs echo "Build start unix" Build start unix echo 1140414275 1140414275 for dir in include lib include user ; do [ ! -d $dir ] || make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- -C $dir || exit 1 ; done make[1]: Entering directory `/home/alex/uClinux-dist-test/include' find . -depth -type l -a ! -name Makefile | xargs rm > /dev/null 2>&1 || exit 0 find . -depth -type d | xargs rmdir > /dev/null 2>&1 || exit 0 Making symlinks in include/ /bin/sh: nios2-linux-uclibc-gcc: command not found Making include/c++ symlink to compiler c++ includes make[1]: Leaving directory `/home/alex/uClinux-dist-test/include' make[1]: Entering directory `/home/alex/uClinux-dist-test/lib' for i in ../include ../include /home/alex/uClinux-dist-test/prop ; do if [ -d $i ]; then touch $i/.sgbuilt_lib; make -C $i || exit $? ; fi; make make_links || exit ; done make[2]: Entering directory `/home/alex/uClinux-dist-test/include' find . -depth -type l -a ! -name Makefile | xargs rm > /dev/null 2>&1 || exit 0 find . -depth -type d | xargs rmdir > /dev/null 2>&1 || exit 0 Making symlinks in include/ /bin/sh: nios2-linux-uclibc-gcc: command not found Making include/c++ symlink to compiler c++ includes make[2]: Leaving directory `/home/alex/uClinux-dist-test/include' make[2]: Entering directory `/home/alex/uClinux-dist-test/lib' Making symlinks in lib/ make[2]: Leaving directory `/home/alex/uClinux-dist-test/lib' make[2]: Entering directory `/home/alex/uClinux-dist-test/include' find . -depth -type l -a ! -name Makefile | xargs rm > /dev/null 2>&1 || exit 0 find . -depth -type d | xargs rmdir > /dev/null 2>&1 || exit 0 Making symlinks in include/ /bin/sh: nios2-linux-uclibc-gcc: command not found Making include/c++ symlink to compiler c++ includes make[2]: Leaving directory `/home/alex/uClinux-dist-test/include' make[2]: Entering directory `/home/alex/uClinux-dist-test/lib' Making symlinks in lib/ make[2]: Leaving directory `/home/alex/uClinux-dist-test/lib' make[2]: Entering directory `/home/alex/uClinux-dist-test/lib' Making symlinks in lib/ make[2]: Leaving directory `/home/alex/uClinux-dist-test/lib' make[1]: Leaving directory `/home/alex/uClinux-dist-test/lib' make[1]: Entering directory `/home/alex/uClinux-dist-test/include' find . -depth -type l -a ! -name Makefile | xargs rm > /dev/null 2>&1 || exit 0 find . -depth -type d | xargs rmdir > /dev/null 2>&1 || exit 0 Making symlinks in include/ /bin/sh: nios2-linux-uclibc-gcc: command not found Making include/c++ symlink to compiler c++ includes make[1]: Leaving directory `/home/alex/uClinux-dist-test/include' make[1]: Entering directory `/home/alex/uClinux-dist-test/user' for i in boa dhcpd games net-snmp /home/alex/uClinux-dist-test/vendors/Altera/ni os2nommu/. /home/alex/uClinux-dist-test/prop; do if [ -d $i ]; then touch $i/.sgbuilt_user; make -C $i || exit $? ; fi; done make[2]: Entering directory `/home/alex/uClinux-dist-test/user/boa' for i in src ; do make -C $i all || exit ; done make[3]: Entering directory `/home/alex/uClinux-dist-test/user/boa/src' nios2-linux-uclibc-gcc -Os -g -Dlinux -D__linux__ -Dunix -D__uClinux__ -DEMBED -I/home/alex/uClinux-dist-test -fno-builtin -c -o alias.o alias.c make[3]: nios2-linux-uclibc-gcc:命令未找到 make[3]: *** [alias.o] 错误 127 make[3]: Leaving directory `/home/alex/uClinux-dist-test/user/boa/src' make[2]: *** [all] 错误 2 make[2]: Leaving directory `/home/alex/uClinux-dist-test/user/boa' make[1]: *** [all] 错误 2 make[1]: Leaving directory `/home/alex/uClinux-dist-test/user' make: *** [subdirs] 错误 1 [alex@localhost uClinux-dist-test]$ Why do not find the command : nios2-linux-uclibc-gcc? Thank you.
