20 years agobuildroot to build toolchain on Linux
TO_BE_DONE
20 years agoHi hippo:
I am testing boa and DHCP now. Frist I must config the ethernet setting. I use the ifconfig command as follow: ifconfig eth0 inet addr:192.168.0.85 Mask:255.255.255.0 up but I find the command not setting my dvb success. I use ping command use loopback address(127.0.0.1),it's OK. I think the problem maybe I use wrong config method. I want to use ifconfig -h command to look for help,but no any information display. Can you help me? Thank you.
