20 years agobuildroot to build toolchain on Linux
TO_BE_DONE
20 years agohi hippo:
I remove old buildroot ,rootfs, linux-2.6.x, linux-2.6.15.4 frisst.Then rebuilded the toolschian follow your new update with ./build0207. But I still failed .I think the failed reason is ccache.samba.org web site I got follow informathion: /buildroot/build_nios2/staging_dir/bin/nios2-linux-uclibc-objcopy PREFIX=/home/alex/buildroot/build_nios2/root utils install_utils make[1]: Entering directory `/home/alex/buildroot/toolchain_build_nios2/uClibc' CC utils/readelf STRIP -x -R .note -R .comment ../utils/readelf make CROSS=" /home/alex/buildroot/build_nios2/staging_dir/bin/nios2-linux-uclibc-" CC="/home/alex/buildroot/build_nios2/staging_dir/bin/nios2-linux-uclibc-gcc" -C utils utils_install install -d /home/alex/buildroot/build_nios2/root/usr/bin# install -m 755 ../utils/readelf /home/alex/buildroot/build_nios2/root/usr/bin/readelf make[1]: Leaving directory `/home/alex/buildroot/toolchain_build_nios2/uClibc' touch -c /home/alex/buildroot/build_nios2/root/usr/bin/ldd wget --passive-ftp -P /home/alex/buildroot/dl http://ccache.samba.org/ftp/ccache/ccache-2.4.tar.gz (http://ccache.samba.org/ftp/ccache/ccache-2.4.tar.gz) --12:14:39-- http://ccache.samba.org/ftp/ccache/ccache-2.4.tar.gz (http://ccache.samba.org/ftp/ccache/ccache-2.4.tar.gz) => `/home/alex/buildroot/dl/ccache-2.4.tar.gz' 正在解析主机 ccache.samba.org... 66.70.73.150 正在连接 ccache.samba.org[66.70.73.150]:80... 已连接。 已发出 HTTP 请求,正在等待回应... 404 Not Found 12:14:40 错误 404:Not Found。 make: *** [/home/alex/buildroot/dl/ccache-2.4.tar.gz] 错误 1 [alex@localhost download]$ I will search other web to obtain the ccache-2.4.tar.gz, then download it in ~/download dir.If you know other web site what have the file ,pelease tell me. 2) I make process, I got other information about watchdog. patch file drivers/char/watchdogs/Makefile Hunk# 1 Failed at 39 1 out of 1 hunk Failed -saving rejects to file drivers/char/watchdogs/Makefile.rej
