20 years agobuildroot to build toolchain on Linux
TO_BE_DONE
20 years agoYou should find them on the nios2 doc and the forum.
You should download to ram first, and after you have a lot of tests, then download to flash. check, http://www.altera.com/literature/ug/ug_nio..._programmer.pdf (http://www.altera.com/literature/ug/ug_nios2_flash_programmer.pdf) Sorry, I can not help you. I don't use CFI flash.
