8 years agoBuffer chain output from DLL in ALTDLL
Hi, I require clocks with different phase shifts. Theoretically, the outputs at each stage of the buffers in the buffer chain of DLL in ALTDLL megafunction should do it. However, ALTDLL outputs only ...
8 years agoI select one out of eight clocks every microsecond and sample the incoming signal for 200ns. Eight phase-shifts results in 250ps delay b/w clocks
