14 years ago
BSP Generation Error
I've tried to generate BSP using NIOS II 11.1 SBT for Eclipse (right click project ->NIOS II -> Generate BSP), but got the following error.
Error executing 'nios2-bsp-generate-files --bsp-dir . --settings settings.bsp', unexpected return code 1.
Error message:
SEVERE: Available BSP type values for the --type argument are: [hal, ucosii]
SEVERE: nios2-bsp-generate-files failed.
Anyone who encountered this issue before? What's the cause of this error? How to fix it?
Thanks and Regards,
Den
    --- Quote Start ---
    Hi All,
    I finally managed to Generate the BSP using NIOS II 11.1 SBT for Eclipse.
    I just needed to copy the ff software packages to NIOS IDE: FreeRTOS, LWIP, HAL, as the software is based on Engineering Sprit'sFreertos-NIOS port.
    Thanks Yocto for help.
    Dennis
    --- Quote End ---
    Hey dennis, how did you managed to Generate the BSP ?
    i still don't see free_rtos in the operation system list when creating new BSP...
    thank
    Mor
    Hi All,
    Dennis
    The error speaks for itself:
    --- Quote Start ---
    BSP type "freertos" unknown
    --- Quote End ---
    You have to use HAL. I am not sure if FreeRTOS supports HAL, you might need to port it.
    Hi Yocto,
    Thanks for the reply.
    The thing is the operating system I'm using is FreeRTOS. The bsp type is "freertos".
    Another issue I found is that when I tried to right-click the project, then go to "NIOS II" -> "BSP Editor". The following error message is displayed in the Problems tab of BSP Editor.
    SEVERE: BSP type "freertos" unknown.
    SEVERE: NullPointerException
    I think I encountered this problem when I replaced my software libraries ("Copy and Replace" the project folder) with the latest one.
    I already cleaned all the projects and rebuild, but I still encountered the problems indicated above. Note that no problems have been encountered whenever I build the project. It's just that I can't re-generate the BSP after compiling to a new system.
    Have you specified --type to nios2-bsp-create-settings? Here is what documentation (http://www.altera.com/literature/hb/nios2/n2sw_nii52016.pdf) for nios2-bsp-create-settings tool says:
    --- Quote Start ---
    --type <OS name>: BSP type. Use ? or types to list available BSP types for this option. Use names to list the display names of available BSP types. For a Nios II DPX system, always set this argument to lwhal.
    --- Quote End ---
    Types available in your setup seem to be either hal or ucosii. The first one stands for Altera's Hardware Abstraction Layer. The former is µc/os-ii (http://en.wikipedia.org/wiki/microc/os-ii).
