14 years agoBSP Generation Error
I've tried to generate BSP using NIOS II 11.1 SBT for Eclipse (right click project ->NIOS II -> Generate BSP), but got the following error. ==================================================== ...
14 years agoHave you specified --type to nios2-bsp-create-settings? Here is what documentation (http://www.altera.com/literature/hb/nios2/n2sw_nii52016.pdf) for nios2-bsp-create-settings tool says:
--- Quote Start --- --type <OS name>: BSP type. Use ? or types to list available BSP types for this option. Use names to list the display names of available BSP types. For a Nios II DPX system, always set this argument to lwhal. --- Quote End --- Types available in your setup seem to be either hal or ucosii. The first one stands for Altera's Hardware Abstraction Layer. The former is µc/os-ii (http://en.wikipedia.org/wiki/microc/os-ii).
