14 years agoBSP Generation Error
I've tried to generate BSP using NIOS II 11.1 SBT for Eclipse (right click project ->NIOS II -> Generate BSP), but got the following error. ==================================================== ...
14 years agoHi Yocto,
Thanks for the reply. The thing is the operating system I'm using is FreeRTOS. The bsp type is "freertos". Another issue I found is that when I tried to right-click the project, then go to "NIOS II" -> "BSP Editor". The following error message is displayed in the Problems tab of BSP Editor. ==================== SEVERE: Available BSP type values for the --type argument are: [hal, ucosii] SEVERE: BSP type "freertos" unknown. SEVERE: NullPointerException ============================= I think I encountered this problem when I replaced my software libraries ("Copy and Replace" the project folder) with the latest one. I already cleaned all the projects and rebuild, but I still encountered the problems indicated above. Note that no problems have been encountered whenever I build the project. It's just that I can't re-generate the BSP after compiling to a new system.
