rshal2
6 years agobootselect pins confusion
Hello, I am a bit confused with bootselect pins on arria V. According to table A-1 from Arria V Device Handbook: 0x0 Reserved
0x1 FPGA (HPS-to-FPGA bridge)
0x2 1.8 V NAND flash memory
0x3 3.0 ...
sstrell
6 years agoI think those names are the functions of the pins after boot (for example NAND_WE is NAND write enable) or if you're not using them for boot select. The 3 pins still use the BSEL encoding from the handbook.
#iwork4intel
rshal2
6 years agoThanks,
But I find it a bit strange, if they are boot selects pins, it means that they are connected to '0' or '1', not to other device.
So, how can such pin have both roles ?
- EBERLAZARE_I_Intel6 years ago
Do you have any followup from your side?
Regards.
I do not really get the question, correct me if I am wrong are you asking why there are two boot select pins for NAND devices?
