rshal2's avatar
rshal2
6 years ago
bootselect pins confusion
I am a bit confused with bootselect pins on arria V.
According to table A-1 from Arria V Device Handbook:
0x0 Reserved
0x1 FPGA (HPS-to-FPGA bridge)
0x2 1.8 V NAND flash memory
0x3 3.0 V NAND flash memory
0x4 1.8 V SD/MMC flash memory with external transceiver
0x5 3.0 V SD/MMC flash memory with internal transceiver
0x6 1.8 V SPI or quad SPI flash memory
0x7 3.0 V SPI or quad SPI flash memory
But in pins descriptions I see the following pins name (5ASXFB5H4F4):
SPIM0_SS0,BOOTSEL0
QSPI_SS0,BOOTSEL1
NAND_WE,BOOTSEL2
From this I understand that when bootsel2=1, it also enablse NAND ? If so, then why the 1st table only enables nand in 0x2,0x3 , i.e. only when bootsel1=1 ?
Thank you !
  • sstrell's avatar
    sstrell
    I think those names are the functions of the pins after boot (for example NAND_WE is NAND write enable) or if you're not using them for boot select. The 3 pins still use the BSEL encoding from the handbook.
    #iwork4intel
    • rshal2's avatar
      rshal2
      But I find it a bit strange, if they are boot selects pins, it means that they are connected to '0' or '1', not to other device.
      So, how can such pin have both roles ?
