17 years agobootloading doesn't starts
I've have a system in CycloneIII EP3C40 with, NIOS + CFI_Flash + .... I want to write in flash .sof & .elf files to boot entire system from flash memory. My application is running fine if ...
17 years agoDaixiwen describes the problem well. Below is the info I received from Altera tech support. The workaround corrected the problem for me.
> > This is a bug of Nios II flash programmer tool v9.0. The behavior of this bug is that NiosII on Cyclone III does not boot up from EPCS if you > programmed SOF and ELF with v9.0 Flash Programmer. > > The workaround: > replace 90\nios2eds\bin\sof2flash.jar with 81\nios2eds\bin\sof2flash.jar >
