17 years agobootloading doesn't starts
I've have a system in CycloneIII EP3C40 with, NIOS + CFI_Flash + .... I want to write in flash .sof & .elf files to boot entire system from flash memory. My application is running fine if ...
17 years agoIt seems that with Quartus 9, the programmer doesn't put the software correctly in the EPCS device when used with a Cyclone III, preventing the Nios to boot.
This is not corrected in SP1, but should in SP2. There is a thread on the subject in the Nios forum.
