9 years agoBooting NIOS from QSPI
Hi, I am trying to boot a nios processor from external qspi flash. I have added a nios and qspi flash ip to my project, set the reset vector of the nios to the base address of the qspi an...
9 years agoHi,
Yes I have checked and double checked the settings in AN730, I am using a max10 and an n25q128 qspi. I have tried both option 4 and 5 with the nios booting from qspi and executing in place and copying to ddr. After more investigation I think I am running into: https://www.altera.com/support/support-resources/knowledge-base/solutions/rd03172015_883.html Where as the nios I am using is a nios/e and the qspi is in a seperate clock domain it doesnt boot. I am trying to find a workaround without having to buy the nios/f license. The example design I looked at from rocketboards (Altera MAX10 10M50 Rev C Development Kit Linux Setup (althought I am not trying to boot linux)) uses the qspi as the boot device but has a nios/f core. I am using quartus 15.1 so I might give the latest quartus a go in case it has been fixed in a later version.
