Booting from Onchip RAM
Hi @IMS,
Thank you for posting in Intel community forum, hope this message find you well and apologies for the delayed in response.
Clarification if I may, situation here is that we have a set of different NIOS with different flash, and you are trying to copy the application of both NIOS into the shared on-chip RAM to run it yes?
And only one of the NIOS application are successfully working?
If that is the case I would recommend the following tutorial here, as it would be a very good starting point for a multiple processor system.
Warm regards.
BB
- BoonBengT_Altera5 years ago
Moderator
Hi @IMS,
Hope this message find you well and good day, unfortunately as we do not receive any response from you to the previous clarification and tutorial that we have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Thank you
Warm Regards
BB- IMS5 years ago
Hi BoonBengT_Intel,
I solved the problem myself. Depending on the booting concept it is necessary to adapt the BSP settings in the Software Project.
Thank you for your time!
IMS
