14 years agoBoard recommendation for MLBS until 60MHz
Hello there! I need to generate a Maximum length binary sequence (MLBS) with an FPGA for a project of mine, which I then have to modulate with a carrier signal. The MLBS needs to be at least 60MHz a...
14 years ago --- Quote Start --- I cannot thank you enough for all the help in my pursuit towards understanding VHDL & FPGA concepts better. I am still going through all the documentation that you've given and its live an information treasure trove for newbies like me. Thank you for that. --- Quote End --- Let me know if anything is not clear, or you've seen explained another way that you liked. I need to update those notes. --- Quote Start --- As a final favour, based on my current requirements which I have tried to explain as much as I could (since the project itself is in a nascent stage and we do not know every specfication of the project as yet!!!), could you please suggest a suitable Altera board, both with and without ADC/DAC so that I can compare the same and then based on my final requirements, I can inform my superiors to order that from the market! Would be very helpful if I have a specific board in mind so that I can work towards tailoring my final specs accordingly. --- Quote End --- I would need at least some requirements to provide a recommendation. If your ADC/DAC requirements are below 100MHz, then the Terasic ADC/DAC board might work for you. Start here http://www.terasic.com and click on the "Daughter boards" product link. If you are using >100MHz ADCs, then Texas Instruments has some evaluation boards with an HSMC adapter. In that case, you would need an FPGA board with HSMC and LVDS support, eg. the Terasic DE115. Look at the Terasic site, and then ask questions. Cheers, Dave
