14 years agoBoard recommendation for MLBS until 60MHz
Hello there! I need to generate a Maximum length binary sequence (MLBS) with an FPGA for a project of mine, which I then have to modulate with a carrier signal. The MLBS needs to be at least 60MHz a...
14 years agoDear Dave,
I cannot thank you enough for all the help in my pursuit towards understanding VHDL & FPGA concepts better. I am still going through all the documentation that you've given and its live an information treasure trove for newbies like me. Thank you for that. As a final favour, based on my current requirements which I have tried to explain as much as I could (since the project itself is in a nascent stage and we do not know every specfication of the project as yet!!!), could you please suggest a suitable Altera board, both with and without ADC/DAC so that I can compare the same and then based on my final requirements, I can inform my superiors to order that from the market! Would be very helpful if I have a specific board in mind so that I can work towards tailoring my final specs accordingly. Regards, Jack
