18 years agoBlockram: RAM model read/write
Hello, Can someone point me out how I can read/write to the following blockram RAM model ? I can read and write to external SRAM, but I am not able to make this work using blockram. Could...
18 years agoAt least, these signals seem to have wrong polarity:
vram_we_sig <= Wr_n;
vram_re_sig <= Rd_n; The other other point is, that the timing may be inappropriate for your design, but that can't be seen from the shown code. FPGA internal RAM act as synchronous RAM, you should check the timing to see if read and write operation occur at the intended moment. Also registered or non-registered read operation can be choosen. I wonder, why conditional assignment (a multiplexer) is used for the RAM input signals, but it shouldn't have any effect.
