Binary Divider
Hi, I'm a new user and want to get used to the Quartus environment to create my own simple binary divider (like the lpm_divider). So wondered if anyone could give me any hints/tips/help please?
I would say have a look at these books as a starting point
Computer Organisation & Design - Patterson and Hennessey Digital Arithmetic - Ercegovac and Lang Computer Arithmetic Algoithms - Isreal Koren and to a lesser degree this one Elementary Functions: Algorithms and Implementation - Muller Trying to implement any mathematical algorithm in hardware might be heavy going to begin but the end result can be very lucrative ;) - Altera_Forum
Do you want a pipelined divider (result every clock cycle after an initial latency) or a serial divider (low throughput)?
Pipelined dividers are big due to the nature of division whereas serial dividers are fairly tiny (approximately 2.5 LEs per bit roughly). A serial divider performs division by using long division which is why it's so small (because the operation is just shift, compare, and subtract). You can also make hybrid serial + parallel dividers where multiple bits are operated on each clock cycle. If you can't find anything leave me a message and I'll see if I can find one of mine. - Altera_Forum
Found some arithmetic design examples in the following link. You may also want to try it out.
http://www.altera.com/support/examples/exm-arithmetic.html - Altera_Forum
If you are just wanting to try out the Altera tool, then you can just instantiate the lpm_divide module in your test HDL and run it through Quartus II's synthesis and place&route. Or, you can write your own HDL code to implement a binary divider if you want (but for the purpose of taking Quartus for a test drive, I think it doesn't matter).
Quartus->File menu has a New Project wizard that takes you through the steps of creating a new Quartus project (just define where your HDL is, what FPGA are you targeting, etc) There is a button on Quartus that looks like the "play" button on a DVD player; clicking on that runs the design through all the necessary tools, pretty simple.
