16 years ago
Bidirectional SPI switch?
This is a complex problem which I am very unsure of, the basic idea is that I want code that switches between 3 SPIs.
I was startled when I noticed the statement that I was about to write
A_SCLK <= C_SCLK
C_SCLK <= A_SCLK
both are true, but this would induce registers, all I want is a wire connection.
-- The idea is that choose either A or B is exclusively
-- connected to C
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity bidir_SPI_switch is
    port(
        A_SCLK, B_SCLK, C_SCLK        :    INOUT STD_LOGIC;
        A_SOMI, B_SOMI, C_SOMI        :    INOUT STD_LOGIC;
        A_SIMO, B_SIMO, C_SIMO        :    INOUT STD_LOGIC;
        A_CSn, B_CSn, C_CSn    :    INOUT STD_LOGIC;
        en, S    : IN BIT
end bidir_SPI_switch;
architecture behaviour of bidir_SPI_switch is
    process(en,S)
    begin
-- MASTER enable
        if en = '0' then
            A_SCLK                   HOW??
            C_SCLK
        else
-- SELECT either A or B
        end if;
    end process;
    I can't make it happen. Have a look at the attachment for the results.
    Basically, it should just be a mechanical switch i.e.
    when en = 0, wire A should be connected to wire C.
    when en = 1, wire B should be connected to wire C.
    -- connected to C
    library IEEE;
        port(
            en, S    : IN BIT
    begin
        process(en,S)
        begin
    -- MASTER enable
            if en = '0' then
                A_SCLK <= C_SCLK;
                B_SCLK <= 'Z';
                C_SCLK <= A_SCLK;
            else
                A_SCLK <= 'Z';
                C_SCLK <= B_SCLK;
                B_SCLK <= C_SCLK;
            end if;
        end process;
    end architecture behaviour;
    --- Quote Start ---
    Some points of the original post seems confused. SPI implies either master or slave role, for this reason none of the standard SPI signals would be bidirectional respectively inoout normally. It's of course possible to design an SPI interface that changes between master and slave role, but you didn't mention this.
    It's also wrong to say that a VHDL assignment involves registers. This is only the case, if it executes under a edge sensitive event condition. You can have combinational process statements as well, they infer multiplexers, as apparently intended here.
    --- Quote End ---
    Apologies for the confusion. What I intend to do is have 3 SPI ports where any of the nodes connected could either be a master or slave. it is a truly bidirectional system then.
    If I have understood you, you have A,B,C SPI interfaces and you want C to talk to either A or B:
    (1) C to A or B
    Since you have chipselect then you can drive both at same time then use chipselect.
    (2) A or B to C: use your switch to drive C
    This pseudocode may explain my idea:
    if OE = ?
        A <= C;
        B <= C;
        C <= 'Z';
    else
        A <= 'Z';
        B <= 'Z';
        if select = ?
            C <= A;
        else
            C <= B;
        end if;
    end if;
