16 years agoBidirectional SPI switch?
This is a complex problem which I am very unsure of, the basic idea is that I want code that switches between 3 SPIs.
I was startled when I noticed the statement that I was about to write A_SCLK <= C_SCLK C_SCLK <= A_SCLK both are true, but this would induce registers, all I want is a wire connection.
-- The idea is that choose either A or B is exclusively
-- connected to C
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity bidir_SPI_switch is
port(
A_SCLK, B_SCLK, C_SCLK : INOUT STD_LOGIC;
A_SOMI, B_SOMI, C_SOMI : INOUT STD_LOGIC;
A_SIMO, B_SIMO, C_SIMO : INOUT STD_LOGIC;
A_CSn, B_CSn, C_CSn : INOUT STD_LOGIC;
en, S : IN BIT
end bidir_SPI_switch;
architecture behaviour of bidir_SPI_switch is
process(en,S)
begin
-- MASTER enable
if en = '0' then
A_SCLK HOW??
C_SCLK
else
-- SELECT either A or B
end if;
end process;
