BGA TDN-741-954-61 (MPN# 5SGXMABK3H40C2LG ) short bridging issue for BGA
Hi Intel Team,
We found the solder bridging issue observed on BGA component (Part No: TDN-741-954-61_MPN#5SGXMABK3H40C2LG ) used in the Teradyne TDN-627-000-40 model.
Background:
We have been experiencing intermittent (on-and-off) solder bridging defects, predominantly located at the edge of the BGA during SMT assembly. Although the occurrence rate is relatively low (16/1200 boards), the repetition across builds has raised concern on potential component-related contribution.
To further understand the failure mechanism, a Shadow Moiré (TherMoire) analysis was conducted to evaluate the package coplanarity behavior across the full reflow temperature profile.
Summary of Key Findings:
- De-soldered (failed) sample shows higher warpage, with coplanarity up to 9.8 mil
- Incoming reference sample shows lower warpage, with max ~6.4 mil
- Warpage remains ~5 mil even near peak reflow temperature (220–250°C)
- Observed defect location (BGA edge bridging) is consistent with warpage-induced coplanarity.
These findings suggest that package warpage at elevated temperature could be a contributing factor to the observed solder bridging.
Please do advise and provide the details following questionnaire: -
- Confirm warpage/coplanarity specification limits at reflow condition and whether our observed (~9.8 mil) is within acceptable range.
- Provide details on BGA material properties, especially Tg and its impact on warpage behavior during reflow.
- Explain the difference between good (incoming) vs failed sample in terms of warpage.
- Share warpage control method and monitoring at supplier side (e.g., measurement method, control limits).
- Provide lot traceability check to identify any variation or abnormality if have.
- Advise on risk of solder bridging due to warpage and recommended mitigation as the stencil opening followed recommendation.
- Flex Penang would like to send for FA. Please kindly provide RMA, forwarder account, shipping details, attention to and contact number.
Norizwan
