16 years agoBenchmark - how to raise clock frequency?
Hello, currently I'm doing some benchmark evaluation (dhrystone) on my Cyclone III Evalboard "BeMicro". I'm using the Nios II/e for the simplest option. The benchmark tells me 0,124 MIPS/MHz,...
16 years agoThank you for the answer.
--- Quote Start --- This 215MHz value looks quite optimistic. According to Altera's document it was measured on a EP3C40F324C6. I guess you have a C7 or C8 on your board, that will be a bit slower. --- Quote End --- You're right, i've got the C8 speed grade. The "Cyclone III Device Handbook, Vol2, page 25" shows differences in speed only around 20% between C6 and C8. So the speed grade is one reason, but cannot be the only one, from my point of view. --- Quote Start --- Do you have timing violations when you recompile your design with a higher frequency? --- Quote End --- Sorry, i didn't get that... Which timing violations do you mean? I don't have errors when compiling, but when i try to run the benchmark with the NIOS II IDE (Eclipse), either the download verify fails or the processor does not respond, if the PLL frequency is configured too high. --- Quote Start --- You can try and add some pipelines, it will help increase the fmax. As an example a Avalon MM pipeline bridge between the CPU instruction and data masters and the JTAG debug module usually helps. --- Quote End --- Hm, I added this pipeline bridge, but I can't see much difference now. The clock frequency is stucked at around 130MHz for eco, ~80MHz for the standard and ~100MHz for the fast NIOS.
