SusanB
5 years agoBehavior of Max10 if nSTATUS pullup is missing?
As part of reliability analysis, I am being asked to explain what happens (or could happen) if the pull-up resistor on nSTATUS opens. My initial response was to say it is fine because nSTATUS is just...
- 5 years ago
nSTATUS must be connected as it will affect configuration if not connected. Any pull down will cause configuration failure.
Hence nSTATUS is important as nCONFIG.
You can also refer to MAX 10 pin connection guidelines for more information:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/max-10/PCG-01018.pdf
Aiman
NurAiman_M_Intel
5 years agoHi,
Aiman
