12 years agobeginners question: MAX V capacity needed for simple glue logic
Hello, I am looking for a simple glue logic solution. 2 image sensors will simultaneously output 8-bit image data at a rate of 25Mhz. I want to import this into a microcontroller as 8 bit d...
12 years agoYou have a point there.
I found that the initial problem can very well be done with a MAX V, so it is worth it to install Quartus an put it to the test. I will go ahead and do that.
