12 years agobeginners question: MAX V capacity needed for simple glue logic
Hello, I am looking for a simple glue logic solution. 2 image sensors will simultaneously output 8-bit image data at a rate of 25Mhz. I want to import this into a microcontroller as 8 bit d...
12 years ago --- Quote Start --- And if you use ripple logic? 2 inputs, one carry in one carry out? --- Quote End --- That's the default adder implementation, also used for the binary counter. It's easy to check the implementation in Quartus netlist viewer.
