12 years agobeginners question: MAX V capacity needed for simple glue logic
Hello, I am looking for a simple glue logic solution. 2 image sensors will simultaneously output 8-bit image data at a rate of 25Mhz. I want to import this into a microcontroller as 8 bit d...
12 years ago --- Quote Start --- MAX V has LEs with 4-bit input LUT similar to Cyclone I to IV. For the mentioned functions like 10-Bit counter or 8-bit adder, you can expect 1 LE per bit. Complex logic might consume additional LEs for intermediate terms. --- Quote End --- And if you use ripple logic? 2 inputs, one carry in one carry out?
