12 years agobeginners question: MAX V capacity needed for simple glue logic
Hello, I am looking for a simple glue logic solution. 2 image sensors will simultaneously output 8-bit image data at a rate of 25Mhz. I want to import this into a microcontroller as 8 bit d...
12 years agoThanks for your quick response.
The clocks are more or less synchronized. The sensors are running from the same clock, but this clock is an oscillator. I found that the signal does not have steep edges. As a result there will be a different skew for each sensor. I might just buffer the clock. That will probably solve this. I was looking for (relatively) simple programmable logic. This could be either a small FPGA or CPLD. What I like about MAX V is the fact that it does not need external memory and that it is really low cost. There is some other functionalities that I want to build in other applications. However, these would use more registers. Now I am thinking: what else can I do with the MAX V? Would it be feasible? I would need some 8 to 10-bit counters and adders. This will definitely not work on a 5M40, but maybe one of the larger models. Can I safely assume that the registers are also the limiting factor here? I mean, if I were to implement a 10-bit counter, would I need 10 LEs then, or could it need more? What about an 8 bit adder? I know I am pushing it now, but it might just work...
