12 years agobeginners question: MAX V capacity needed for simple glue logic
Hello, I am looking for a simple glue logic solution. 2 image sensors will simultaneously output 8-bit image data at a rate of 25Mhz. I want to import this into a microcontroller as 8 bit d...
12 years agoTo decide if 5M40 can do the job, you'll write the code and compile it.
Your description isn't really informative about the possible role of a FIFO. If your glue logic needs to handle asynchronicity of data streams, I guess it won't fit into 32 LEs. By the way, which microcontroller can achieve 50 MByte/s continuous data rate? Or is it only DMA based single frame grabbing?
