16 years agoBeginner questions on HDL component mapping
Hello, I have a couple of confusing points about component port mapping, which I would really appreciate some explanation on. 1) Do the inputs map to inputs only? Can an output of a comp...
16 years agoThank you very much FvM. I'm a little more confused to be honest. So the code I am examining has something like this:
ARCHITECTURE arch of ent IS
signal someSignal1: STD_LOGIC;
signal someSignal2: STD_LOGIC
BEGIN
component1: ENTITY work.LED_FLASHER
PORT MAP (
LEDCLK = someSignal1;
LED=> led_number1 );
component2: ENTITY work.LED_FLASHER
PORT MAP (
LEDCLK => someSignal2,
LED => led_number2 );
END ARCHITECTURE arch
So I have tewdifferent signals mapping to LED_FLASHER, LEDCLK and LED. First is an input and the second is an output. Basically one output 'LED' is used to drive two led's (led_number1 and led_number2). Think of someSignals as two different clocks. And the LED's are flashed according to these clocks. So when someSignals are mapped concurrently, how would this operate? Why wouldn't this create a multiple driver error? Some explanation or a reference is very much appreciated. Cheers.
