16 years agoBeginner questions on HDL component mapping
Hello, I have a couple of confusing points about component port mapping, which I would really appreciate some explanation on. 1) Do the inputs map to inputs only? Can an output of a comp...
16 years ago --- Quote Start --- Basically, for clocks, you wouldnt Allowing multiple drivers allows you to model tri-state buffers. These do not exist internally on a FPGA, but do exist on output pins. --- Quote End --- Thank you very much Tricky. You just explained a "multiple driver" error I have been getting and had no idea what I was doing. Thank you for that. I am still a little confused about multiple mapping. Could you tell me what would happen if I do this multiple mapping the other way. For example,
ARCHITECTURE arch of ent IS
signal CLK: STD_LOGIC;
BEGIN
component1: ENTITY work.LED_FLASHER
PORT MAP (
LEDCLK => CLK );
component2: ENTITY work.LED_FLASHER
PORT MAP (
LEDCLK => CLK );
END ARCHITECTURE arch
What would happen in this case if I do multiple mappings to a component port? Thank you very much for all the input. Cheers.
