16 years agoBeginner Question - Differences between Simulation and Application
Hi, I'm using the Cyclone II FGPA and trying to get some verilog code working. This is a more abstract question - just wondering generally what the most common problem areas are when trying to ...
16 years agoInteresting stuff, thank you.
Any suggestions on how to overcome any issues with buffers or floating values ? I've tried using tri0 instead of wire to describe output lines, which seemed to work in one case where an output was defaulting to a false active... that kind of thing?
