12 years agoBeginner device CPLD/FPGA selection for anti-aliasing filter
Hi all, I am working on a HW design for power analysis of 8channel 50/60Hz signals that are sampled @ around 50kHz / channel. These signals needs to be filtered after sampling before transforma...
12 years agoCIC usage would primarly reduce complexity, that's why it's classically used for multi-rate filters of oversampling ADCs. But I agree that a serial FIR won't consume much resources besides block RAM. In so far it's a straightforward solution, even with quite large number of coefficients if you can afford the RAM capacity.
The WM8731 codec untilized on many Terasic boards can be used with 8 kHz standard sampling rate, or any rate of your choice by adapting the clock frequency.
