12 years agoBeginner device CPLD/FPGA selection for anti-aliasing filter
Hi all, I am working on a HW design for power analysis of 8channel 50/60Hz signals that are sampled @ around 50kHz / channel. These signals needs to be filtered after sampling before transforma...
12 years agoI entered your filter requirements into MATLAB's FDAtool and with the settings shown in the GUI you need about 50 coefficients.
https://www.alteraforum.com/forum/attachment.php?attachmentid=8659 Since you are sampling at 50kHz, and your FPGA/CPLD can run at least at 50MHz to 100MHz, you have at least 1000 FPGA clocks per ADC clock. This means that your filter can easily be implemented using a single multiplier and some RAM. CPLDs do not have these types of resources, so a small FPGA would be more appropriate. A CPLD could probably do it too, but FPGAs are nicer to deal with when doing signal processing, as you have RAM and can use the SignalTap II logic analyzer. --- Quote Start --- For now only the filtering needs to be done, transformation etc is done later by an MCU --- Quote End --- What transformation? If you are only interested in the 50/60Hz signal, then there is a transform called the Goertzel algorithm http://en.wikipedia.org/wiki/goertzel_algorithm that can be used essentially as the FFT but of just one channel. Cheers, Dave
