16 years agobasic problem with cycloneiii
I have a ep3c40q240c8.i can configure it from jtag and also program it's epcs16 and verifiy it.but the fpga after configuration have no effect.for example all pins are 1;no output affected by input;n...
16 years agoif you can check your image via jtag and it runs as expected, then the source should be epcs & fpga connetion related.
could you verify that the MSEL pins are setup for AS mode ? when powering up the system, do you see the fpga request at the epcs pins ? you should see the DCLK and other signals... if this happens, do you see changes at the output of your epcs device that it is responding ?
