9 years agoBasic example of lpm_counter1 disabled when in overflow
Hi all I need to have a counter that when overflows is set to a predefined value and stops counting. Then only an external signal of clear can restart (from 0) the counter. I thought to use the c...
9 years agoI jumped to same conclusion but indeed I was not able to find a solution to that!
Now thanks to you it is showed here: DFFE! Thanks a lot
