12 years agobandwidth for Cyclone IV(-8 grade) and 32-bit DDR2 SDRAM
I want to use Cyclone IV(-8 grade) and 32-bit DDR2 SDRAM to store some high bandwidth AD conversion results. But I am not sure if this configuration is feasible or not. Could you please help to ...
12 years agoanakha, thanks a lot for your comment!
You give me many good hints: IO voltage, pin assignment, ... I would like to use parallel interface for ADC, but now it seems better to use LVDS to save pins. besides -8 grade may be slow, I need to consider -6 grade for Cyclone IV. I check and find Cyclone IV can only support up to 200MHz DDR2 clock, so perhaps I need Cyclone V which supports up to 400MHz DDR2 clock [@ Altera's External Memory Interface Solutions Center].
