16 years agoBad Pins
I am a rookie. I am working on my fourth MAX II design. I am using Quartus II Version 9 SP2. The problem I am having is that several pins on EPM1270 do not work. For example. I have four test...
16 years agoThanks to both of you for your suggestions. I will try them today.
I certainly don't expect that it would be a problem with Quartus, but it seems so strange. I worked with Quartus quite a bit about a year ago and never had any problems like this. It is a new board. All the pins are assigned correctly. Again thank you. John
