17 years agobad configuration snheme of MSEL , cycloneIII
hello VCCIO of the banks in which the configuration pins reside is 3.3V the EPCS64 used is powered by 3.3V and my big problem is : the MSEL pins are [3..0] : 0100 => meaning acti...
17 years agoHi Amzi,
you could be a little bit more precise in describing the problem. Start by telling what device you use and what you mean by the wording "configuration time". If this is the time until conf_done goes high then, depending on the amount of configuration data, this may be OK for fast mode. Harald
