9 years ago(Avalon-MM) identical slave outside master's address range (??)
Hi all,
In short: I have two identical interfaces, but Qsys tells me the slave is outside the master's address range. I don't understand what's going on and why they would be different. Both have the address unit set to WORDS not SYMBOLS. So they should be the same(?) I recieve this error in Qys that tells me the slave is addressable with 29 bits, and the master with a weird partial 29 bits. error: <master interface>: <slave interface> (0x0..0x1fff ffff) is outside the master's address range (0x0..0x11ff ffff)However, they are identical, and in component editor, both interfaces have the address unit in WORDS, and bits per symbol as 8 bits. I listed them below (the point is they are identical). The interfaces are address[23:0], data[143:0], and byteenable[17:0]. avalon-mm (master): avm_mem_write avm_mem_read avm_mem_address[23:0] avm_mem_writedata[143:0] avm_mem_readdata[143:0] avm_mem_waitrequest avm_mem_response[1:0] avm_mem_byteenable[17:0] avalon-ms (slave): avs_s0_write avs_s0_read avs_s0_address[23:0] avs_s0_writedata[143:0] avs_s0_readdata[143:0] avs_s0_waitrequest avs_s0_response[1:0] avs_s0_byteenable[17:0] Any help with understanding with what's going on I would be grateful. There have been other times that this has confused me a bit, so if you can make it clear, I would appreciate! I also attached photos if they help.
1 Reply
Just an update. Daixiwen (post# 5 at http://www.alteraforum.com/forum/showthread.php?t=33226) has a really good short explanation of addressing.
In addition, I just found out (after a couple months of looking into this) that what I was doing is illegal...that's why the behavior seemed odd. All my other interfaces (32b and 64b) with exact matching Master-Slave data widths are able to connect without problem, except this 144-bit one. As per the Avalon -MM specification, however, data widths must be a power of 2 (from 8 to 1024)!
