13 years ago
Avalon data bus between two fpgas
I need a little advice/direction regarding connecting two fpgas via a bus.
HW setup
Stratix III (DE3) Stratix V
8 x LVDS Tx pairs ---------------------> 8 x LVDS Rx pairs
Any other I/O requirement for signaling is flexible. But for data, the DE3->Stratix V is limited at these 8 LVDS pairs.
The bus has to be capable of running at around 10g in total. i.e. around 1.2-1.4Gbps per LVDS pair.
Data is mainly from the DE3 to the Stratix V.
Ideally I would like to have seamless Avalon interfaces on both sides.
Can a dual-clock Avalon ST Fifo span across to the other FPGA via the AltLVDS megafunction?
e.g.
On the Stratix III (DE3)
I configure the Dual Clock Fifo
I use the SGDMA(scatter gather) to take data and Stream it out to a Dual Clock Fifo using Avalon ST.
I export the signals of the output side of the Dual Clock Fifo.
I connect the signals to the alt-lvds Tx megafunction.
The valid signal of the FIFO will act as the LVDS Clock for the transfer.
On the Stratix V side.
I receive the data via the alt-lvds Rx megafunction.
I put it in another Dual Clock FIFO and another SGDMA to read the data.
Can all this achieve around 10G..
Comments and suggestions (or complete alternate methods) welcome.
Zubair
    Yes. I will need a frame clock as well. I think I missed it out and its available in the hardware layout as well. Will double check.
    Also, I checked the Avalon ST spec. It has a valid signal. This should be usable to generate the frame clock using the Alt-lvds megafunction itself.
    Thank-you. Seems there are no obvious mistakes.. I guess I'll go ahead and play.
    Cheers
    Zubair
    Try it and see.
    Since the ALTLVDS interface will be serializing and deserializing data, you will also need a frame clock. If your data can accommodate some 'extra' symbols, then you can convert the Avalon-ST start-of-packet, end-of-packet, etc, wires into symbols in the data stream. This is how the JTAG-to-Avalon-ST interface works - read the following for details
    http://www.ovro.caltech.edu/~dwh/correlator/pdf/altera_jtag_to_avalon_analysis.pdf
    http://www.ovro.caltech.edu/~dwh/correlator/pdf/altera_jtag_to_avalon_analysis.zip
    This might give you a few ideas.
    Cheers,
    Dave
