13 years agoAvalon data bus between two fpgas
Hi, I need a little advice/direction regarding connecting two fpgas via a bus. HW setup Stratix III (DE3) Stratix V 8 x LVDS Tx pairs ------------------...
13 years agoTry it and see.
Since the ALTLVDS interface will be serializing and deserializing data, you will also need a frame clock. If your data can accommodate some 'extra' symbols, then you can convert the Avalon-ST start-of-packet, end-of-packet, etc, wires into symbols in the data stream. This is how the JTAG-to-Avalon-ST interface works - read the following for details http://www.ovro.caltech.edu/~dwh/correlator/pdf/altera_jtag_to_avalon_analysis.pdf http://www.ovro.caltech.edu/~dwh/correlator/pdf/altera_jtag_to_avalon_analysis.zip This might give you a few ideas. Cheers, Dave
