13 years agoAvalon data bus between two fpgas
Hi, I need a little advice/direction regarding connecting two fpgas via a bus. HW setup Stratix III (DE3) Stratix V 8 x LVDS Tx pairs ------------------...
13 years agoYes. I will need a frame clock as well. I think I missed it out and its available in the hardware layout as well. Will double check.
Also, I checked the Avalon ST spec. It has a valid signal. This should be usable to generate the frame clock using the Alt-lvds megafunction itself. Thank-you. Seems there are no obvious mistakes.. I guess I'll go ahead and play. Cheers Zubair
