13 years agoAuto switching between ADC channel in DE0-Nano
Hello, I'm want to create a program to collect data from 4 microphone using De0-nano board. I tried to create an auto switching program for 2 potensiometer ,using the basic ADC demo from terasic. I u...
11 years agoI thought I had a solution and this code seems to work but the channel 1 bleeds into channel 2 if channel 2 is set to 3.3 V. I can't figure out if it is a wire /antenna problem or code problem. This is especially prevalent when switchcounter is very small. I'd like switch counter to be 0 so I can sample fast, but I can't tell if it is working or not.
Note for this to work I have to change the if (cont == 1) to 1 from 2. it appeared that the ADC chip was off by 1 bit if using all channels. possibly I have other problems. module ADC_CTRL2 ( iCLK, iCLK_n, oCH0, oCH1, oCH2, oCH3, oCH4, oDIN, oCS_n, oSCLK, oCH, iDOUT ); input iCLK; input iCLK_n; output [11:0] oCH0; output [11:0] oCH1; output [11:0] oCH2; output [11:0] oCH3; output [11:0] oCH4; output [1:0] oCH; output oDIN; output oCS_n; output oSCLK; input iDOUT; reg data =0; // serial address data out reg go_en=1; // always enabled after power up reg [1:0] ch_sel = 2'b00; // Start at channel 0 reg [1:0] chOUT = 2'b00; // Register to store channnel output reg sclk; reg [3:0] cont; reg [3:0] m_cont; reg [11:0] adc_data; reg [11:0] ch0; reg [11:0] ch1; reg [11:0] ch2; reg [11:0] ch3; reg [11:0] ch4; reg [8:0] switchcount; // Slow enough to see at 21 bits. ~ 1 change per sec at 15 very fast assign oCS_n = ~go_en; assign oSCLK = (go_en)? iCLK:1'b1; assign oDIN = data; assign oCH0 = ch0; assign oCH1 = ch1; assign oCH2 = ch2; assign oCH3 = ch3; assign oCH4 = ch4; assign oCH = chOUT; always@(posedge iCLK ) // always running begin cont <= cont + 4'b001; end always@(posedge iCLK_n) begin if(iCLK_n) begin // on some clock check to see if timer expired m_cont <= cont; switchcount <= switchcount + 1; if (switchcount == 0) //if last bit is set the increment to next sample addresss begin ch_sel <= ch_sel + 1; // increment the address end end end always@(posedge iCLK_n ) // always running begin if(iCLK_n) begin if (cont == 1) //MSB add in MSB if using all 8 ADC inputs data <= 0; else if (cont == 2) // Middle Bit data <= ch_sel[1]; else if (cont == 3) // LSB data <= ch_sel[0]; else data <= 0; // if not sending out address send out 0 to DOUT end end always@(posedge iCLK) begin begin if(iCLK) begin if (m_cont == 4) adc_data[11] <= iDOUT; else if (m_cont == 5) adc_data[10] <= iDOUT; else if (m_cont == 6) adc_data[9] <= iDOUT; else if (m_cont == 7) adc_data[8] <= iDOUT; else if (m_cont == 8) adc_data[7] <= iDOUT; else if (m_cont == 9) adc_data[6] <= iDOUT; else if (m_cont == 10) adc_data[5] <= iDOUT; else if (m_cont == 11) adc_data[4] <= iDOUT; else if (m_cont == 12) adc_data[3] <= iDOUT; else if (m_cont == 13) adc_data[2] <= iDOUT; else if (m_cont == 14) adc_data[1] <= iDOUT; else if (m_cont == 15) adc_data[0] <= iDOUT; else if (m_cont == 1) // on first clock store data to output port begin ch4 <= adc_data; case (ch_sel) // Select last channel data store to corresponding output port 3'b00 : ch0 <= adc_data; 3'b01 : ch1 <= adc_data; 3'b10 : ch2 <= adc_data; 3'b11 : ch3 <= adc_data; default : ch4 <= adc_data; endcase chOUT <= ch_sel; end end end end endmodule
