13 years ago
Auto switching between ADC channel in DE0-Nano
Hello, I'm want to create a program to collect data from 4 microphone using De0-nano board. I tried to create an auto switching program for 2 potensiometer ,using the basic ADC demo from terasic. I used counter to count for 1 second then change the channel selector, but it didn't work. Can somebody help?
the part of the code was like this
always @ (posedge iCLK)
begin
cont <= cont + 1;
switchcount <= + 1;
end
always @ (posedge iCLK_n)
begin
iCH <= 0;
if (cont == 2)
data <= iCH[2];
else if (cont == 3)
data <= iCH[1];
else if (cont == 4)
data <= iCH[0];
else
data <= 0;
if (switchcount == 50000000)
iCH <= iCH + 1;
end
    I thought I had a solution and this code seems to work but the channel 1 bleeds into channel 2 if channel 2 is set to 3.3 V. I can't figure out if it is a wire /antenna problem or code problem. This is especially prevalent when switchcounter is very small. I'd like switch counter to be 0 so I can sample fast, but I can't tell if it is working or not.
    Note for this to work I have to change the if (cont == 1) to 1 from 2. it appeared that the ADC chip was off by 1 bit if using all channels. possibly I have other problems.
    module ADC_CTRL2 (
    iCLK,
    iCLK_n,
    oCH0,
    oCH1,
    oCH2,
    oCH3,
    oCH4,
    oDIN,
    oCS_n,
    oSCLK,
    oCH,
    iDOUT
    input iCLK;
    input iCLK_n;
    output [11:0] oCH0;
    output [11:0] oCH1;
    output [11:0] oCH2;
    output [11:0] oCH3;
    output [11:0] oCH4;
    output [1:0] oCH;
    output oDIN;
    output oCS_n;
    output oSCLK;
    input iDOUT;
    reg data =0; // serial address data out
    reg go_en=1; // always enabled after power up
    reg [1:0] ch_sel = 2'b00; // Start at channel 0
    reg [1:0] chOUT = 2'b00; // Register to store channnel output
    reg sclk;
    reg [3:0] cont;
    reg [3:0] m_cont;
    reg [11:0] adc_data;
    reg [11:0] ch0;
    reg [11:0] ch1;
    reg [11:0] ch2;
    reg [11:0] ch3;
    reg [11:0] ch4;
    reg [8:0] switchcount; // Slow enough to see at 21 bits. ~ 1 change per sec at 15 very fast
    assign oCS_n = ~go_en;
    assign oSCLK = (go_en)? iCLK:1'b1;
    assign oDIN = data;
    assign oCH0 = ch0;
    assign oCH1 = ch1;
    assign oCH2 = ch2;
    assign oCH3 = ch3;
    assign oCH4 = ch4;
    assign oCH = chOUT;
    always@(posedge iCLK )
    // always running
    begin
    cont <= cont + 4'b001;
    end
    always@(posedge iCLK_n)
    begin
    if(iCLK_n)
    begin // on some clock check to see if timer expired
    m_cont <= cont;
    switchcount <= switchcount + 1;
    if (switchcount == 0) //if last bit is set the increment to next sample addresss
    begin
    ch_sel <= ch_sel + 1; // increment the address
    end
    end
    end
    always@(posedge iCLK_n )
    // always running
    begin
    if(iCLK_n)
    begin
    if (cont == 1) //MSB add in MSB if using all 8 ADC inputs
    data <= 0;
    else if (cont == 2) // Middle Bit
    data <= ch_sel[1];
    else if (cont == 3) // LSB
    data <= ch_sel[0];
    else data <= 0; // if not sending out address send out 0 to DOUT
    end
    end
    always@(posedge iCLK)
    begin
    begin
    if(iCLK)
    begin
    if (m_cont == 4)
    adc_data[11] <= iDOUT;
    else if (m_cont == 5)
    adc_data[10] <= iDOUT;
    else if (m_cont == 6)
    adc_data[9] <= iDOUT;
    else if (m_cont == 7)
    adc_data[8] <= iDOUT;
    else if (m_cont == 8)
    adc_data[7] <= iDOUT;
    else if (m_cont == 9)
    adc_data[6] <= iDOUT;
    else if (m_cont == 10)
    adc_data[5] <= iDOUT;
    else if (m_cont == 11)
    adc_data[4] <= iDOUT;
    else if (m_cont == 12)
    adc_data[3] <= iDOUT;
    else if (m_cont == 13)
    adc_data[2] <= iDOUT;
    else if (m_cont == 14)
    adc_data[1] <= iDOUT;
    else if (m_cont == 15)
    adc_data[0] <= iDOUT;
    else if (m_cont == 1) // on first clock store data to output port
    begin
    ch4 <= adc_data;
    case (ch_sel) // Select last channel data store to corresponding output port
    3'b00 : ch0 <= adc_data;
    3'b01 : ch1 <= adc_data;
    3'b10 : ch2 <= adc_data;
    3'b11 : ch3 <= adc_data;
    default : ch4 <= adc_data;
    endcase
    chOUT <= ch_sel;
    end
    end
    end
    end
    endmodule
    Would you kindly post your solution? I'm having the same problem.
    Would it be possible to post your solution. I am having the same problem.
    if i want to read just 2 input how about switch count that i use ?
    i want to read 2 sensor LDR(light dependent resistor)
    Sorry, forgot to mention that the cont is only 4 bit long, so it will resets after 16 cycles. the iCH is the 3-bit data for mux input (because the ADC is 8-channel, so it is like the channel selector). Anyway, the problem already solved. I think you're right too, the iCH is the problem. I made another file in the project specific for switching channels and it works. Thank you Cris72
    I don't have the adc demo code here, so I can't fully understand the exact purpose and usage of data and iCH.
    The problem is definitely with the iCH <= 0 assignment in the very beginning of second always block: this will be executed at each clock pulse and will keep iCH in the zero state.
    Anyway I think your code is somehow wrong; cont never resets and it would keep on growing, so the cont=x conditions would be hit only once and then data will be always 0.
